A control fabric link to the specified slot has failed. The redundant control fabric link (available only in dual-MM operation) has been activated.
Please refer to the event HAL.Sys.InPortDown indicating the failed link details. The affected I/O blade or fabric module should be removed and its midplane connector inspected for damage. If none is found, the blade can be reseated to see if the link recovers. If the link fails again, the affected MM should be removed and connectors inspected for damage. If none is found, the MM should be reseated. Note that if the MM through which the reroute has taken place is removed or otherwise failed the I/O blade or fabric module will also fail.
Warning
Control fabric traffic to %ioslot% has been rerouted through %mm% due to a failed link.
| Name | Type |
| ioslot | String |
| mm | String |
